I would like to have a DOB and Age fields in one of my forms, and if a
respondent enters DOB it will save DOB, if a respondent enters Age it
should convert that to DOB and save on the table. Is there any way to
accomplish that?
On Sun, Jan 29, 2017 at 1:25 PM, A.N.M AL-IMRAN wrote:
> Hi Friends,
> respondent enters DOB it will save DOB, if a respondent enters Age it should
> convert that to DOB and save on the table. Is there any way to accomplish
> that?
> Thanks,
> Imran
> "ODK Community" group.
should
accomplish
that?
You can use the Filter feature in Aggregate to hide whatever rows or
columns you want.
On Sat, Feb 4, 2017 at 12:11 AM, A.N.M AL-IMRAN wrote:
> Dear Yaw,
> This is an excellent and very helpful example. Consequently, a question came
> to my mind: is there a way to hide the note column on Aggregate?
> Regards,
> Imran
> A N M AL IMRAN (Imran)
> Brossard, QC
> Canada
> Cell: +1 (438) 501 3576
> On 3 February 2017 at 12:10, A.N.M AL-IMRAN wrote:
>> Dear Yaw,
>> came to my mind: is there a way to the note column?
>> Regards,
>> Imran
>> Brossard, QC
>> Canada
>> On 3 February 2017 at 01:04, Yaw Anokwa wrote:
>>> Hi Imran,
>>> Attached is a sample form that asks a user to pick DOB or age. If they
>>> select DOB, it estimates age. If they select age, it estimates DOB.
>>> Dates are tricky and I didn't spend a ton of time on this, so you
>>> should test edge cases and make sure it does what you want.
>>> Yaw
>>> > Hi Friends,
>>> > should
>>> > accomplish
>>> > that?
>>> > Thanks,
>>> > Imran
>>> > Groups
>>> > an
>>> You received this message because you are subscribed to a topic in the
>>> Google Groups "ODK Community" group.
>>> To unsubscribe from this topic, visit
>>> https://groups.google.com/d/topic/opendatakit/NhlmpTs4FYo/unsubscribe.
>>> To unsubscribe from this group and all its topics, send an email to
a
should
accomplish
that?
Groups
send
