Docker-compose build error : Service 'secrets' failed to build :unauthorized , authentication required
I would like to install odk centrall using centOS v.8. I install docker-ce, and docker-compose and follow steps in https://docs.getodk.org/central-install-digital-ocean/#installing-central. When I run docker-compose build in the central directory I am having that error : Docker-compose build error : " Service 'secrets' failed to build :unauthorized , authentication required " and I have tried to fix this error but in vain. Could you please help me out with this?
Server using VM-Centos V8
update .env
install odk central on clean centos V.8
5. Anything else we should know or have? If you have a test form or screenshots or logs, attach below. central]#
postgres uses an image, skipping
mail uses an image, skipping
pyxform uses an image, skipping
enketo_redis_main uses an image, skipping
enketo_redis_cache uses an image, skipping
Building secrets
Step 1/2 : FROM node:12.6.0
12.6.0: Pulling from library/node
a4d8138d0f6b: Pull complete
dbdc36973392: Pull complete
f59d6d019dd5: Pull complete
aaef3e026258: Downloading [========================================> ] 40.25MB/50.07MB
6e454d3b6c28: Downloading [========> ] 35.85MB/215.1MB
c717a7c205aa: Downloading
e8566b4564fe: Waiting
04239395be03: Waiting![docker-compose build error|690x265]
27ace7d95321: Waiting
ERROR: Service 'secrets' failed to build : unauthorized: authentication required
(upload://xgH48OXjUKFLN81B5FevaJ4gIEQ.jpeg)
This doesn't seem specifically related to Central. Did you look at some of the ideas at https://github.com/jupyter/docker-stacks/issues/484?
checked the ideas in https://github.com/jupyter/docker-stacks/issues/484 then I set the correct time using timedatectl set time <hh:mm:ss>. then do a reboot then run docker-compose build again and issue fixed.
thanks
