Hello,
I am trying to download my data from aggregate using STATA 13 but I don't know how. I was told you can use something called metadata is stata to retrieve your data from aggregate just as it appears in the server.
I have used used the briefcase and download function in aggregate to get the data in csv format but it does not appear as it appears on the server, especially the repeat case hence analysis is difficult.
Hi @Raymond_Hodor,
This link provides the various ways of transferring data: https://opendatakit.org/use/aggregate/data-transfer/
ODKmeta (developed by Poverty Action) can help you transform your data for analysis using STATA: https://github.com/PovertyAction/odkmeta
