Downloading data with briefcase does not complete and crashes after an error window
I collected the data with a form which has seen improvements during the operation, so several (3 to 4) versions. The form is encrypted and audit. For data recovery, the briefcase stops and crashes after an error message. I can't get access to the data for use.
I am using an ODK Aggregat v2.0.3 server and an ODK Briefcase for data recovery. I have a Windows 10
To resolve this problem. I changed the version of ODK Briefcase from version 1.14.0 to ODK Briefcase version 1.18.0.jar and I still have no satisfaction.
I have cleared the hystoric of ODK Briefcase still not successful for exporting data.
I have changed recovery folder several times without success
I also tried to send the form to an ODK Central server without success since the form is encrypted.
I would like to know how to push a form encrypt from ODK Aggregate server to ODK Central server.
I ask the community to take a look at the output of my briefcase.log that I attach to my request.
2020-12-07 13:09:56,912 [Thread-3] ERROR o.o.briefcase.ui.export.ExportPanel - Error while exporting forms
java.io.UncheckedIOException: java.nio.file.FileSystemException: C:\Users\PRIVE\Desktop\zdata\FORMULAIRE DU RECENSEMENT DE BASE DE VECTRON T500 - audit.csv: Le processus ne peut pas accťder au fichier car ce fichier est utilisť par un autre processus.
at org.opendatakit.briefcase.reused.UncheckedFiles.write(UncheckedFiles.java:77)
at org.opendatakit.briefcase.reused.UncheckedFiles.write(UncheckedFiles.java:70)
at org.opendatakit.briefcase.export.CsvFieldMappers.aggregatedAuditFile(CsvFieldMappers.java:278)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$null$2(CsvFieldMappers.java:70)
at java.base/java.util.Optional.map(Optional.java:265)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$static$3(CsvFieldMappers.java:70)
at org.opendatakit.briefcase.export.CsvFieldMapper.lambda$compose$0(CsvFieldMapper.java:66)
at org.opendatakit.briefcase.export.CsvFieldMapper.lambda$decorateOutput$1(CsvFieldMapper.java:76)
at org.opendatakit.briefcase.export.CsvFieldMappers.lambda$nonRepeatableGroup$18(CsvFieldMappers.java:290)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:271)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1654)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
at java.base/java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:497)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:274)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at org.opendatakit.briefcase.export.CsvSubmissionMappers.lambda$main$2(CsvSubmissionMappers.java:63)
at org.opendatakit.briefcase.export.ExportToCsv.lambda$null$3(ExportToCsv.java:104)
at java.base/java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195)
at java.base/java.util.stream.ReferencePipeline$11$1.accept(ReferencePipeline.java:442)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:177)
at java.base/java.util.stream.ForEachOps$ForEachTask.compute(ForEachOps.java:290)
at java.base/java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:746)
at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(ForkJoinPool.java:1020)
at java.base/java.util.concurrent.ForkJoinPool.scan(ForkJoinPool.java:1656)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(ForkJoinPool.java:1594)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(ForkJoinWorkerThread.java:177)
Caused by: java.nio.file.FileSystemException: C:\Users\PRIVE\Desktop\zdata\FORMULAIRE DU RECENSEMENT DE BASE DE VECTRON T500 - audit.csv: Le processus ne peut pas accťder au fichier car ce fichier est utilisť par un autre processus.
at java.base/sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:92)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:103)
at java.base/sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:108)
at java.base/sun.nio.fs.WindowsFileSystemProvider.newByteChannel(WindowsFileSystemProvider.java:235)
at java.base/java.nio.file.spi.FileSystemProvider.newOutputStream(FileSystemProvider.java:478)
at java.base/java.nio.file.Files.newOutputStream(Files.java:222)
at java.base/java.nio.file.Files.write(Files.java:3562)
at org.opendatakit.briefcase.reused.UncheckedFiles.write(UncheckedFiles.java:75)
... 49 common frames omitted
2020-12-07 13:10:09,508 [AWT-EventQueue-0] INFO o.o.b.model.TerminationFuture - cancel requested: Main window closed
