Something I have noticed for quite some time and I completely forgot to report: it is not possible to check the submissions submitted to a draft form when the encryption with a passphrase is enabled at the project level. When downloading the data, there is no prompt for entering the passphrase and as a result only the submission metadata can be exported.
ODK Central version:
client (v1.3.2)
server (v1.3.3)
N/A
Select an ODK Central projet in which encryption is enabled
Create a new draft
Test the draft using Enketo or ODK Collect
Download the draft submission
Oh you are definitely right @Matthew_White ! I actually get exactly the behaviour you describe, for both tabs.
I realise now that you mention it that I had never noticed this behaviour with the Submission tab. It is because I use the Testing and the Submission tabs very differently:
in the Testing tab, I immediately want to check the submissions I sent, I click the refresh button, download the submissions and never come back to them later
while for the Submission tab I almost never check the submissions immediately but look at them later so that the page is always refreshed when I want to download the submissions.
And obviously very good to know that I am only one page refresh away from downloading the draft submissions
