Duplicate check in repeat group not working
I am trying to prevent duplicate entries inside a repeat group. I created a unique key using concat() of three fields, but the validation count() is not working in KoboToolbox/ODK Collect.
Add an item in the repeat group (e.g., Product A, Size 1), then add another item with the exact same details. The form should show a warning or block the entry, but it doesn't.
I have used the formula: count(../capture_items[prod_pack_key = current()/prod_pack_key]) <= 1 in the constraint column. I have also tried putting it in the relevant column for a warning note.
inventoryrequest (1).xlsx (582.6 KB)
Hi @abdulahad
When you get a chance, please introduce yourself here. I'd also encourage you to add a real picture as your avatar because it helps build community!
Did you try this solution: Avoiding duplicate selection in repeat group - #22 by LN?
