Greetings, is it possible to add a dynamic filter to a selection? for example, if I have to select an option from a large list to be able to filter and search?
Hello Allan,
I'm not so sure about "search", but for select_one and select_multiple choice option filtering, please refer to the following page from the ODK documentation: https://docs.opendatakit.org/form-logic/?highlight=choice_filter#id48
Thanks, Joseph. I solved my problem, it is a filter for the select one when I write a letter. It only works for select one
That is great to hear!
