I'm not sure if this is possible but I would like to be able to set a label value based on the answer to a previous question. So if someone has selected Answer A on screen 1 I need the label to show label F on the next screen. If Answer B was selected on screen 1 then I would need to show say, label M on the next screen.
The labels wouldn't be the answers themselves but a lookup using a constraint. Is there a way to achieve this using XLSForm?
I did think of using a select one control and referring to that in my label, but realised I needed a way of selecting the value picked up in the lookup..
Not entirely sure what you are asking, but here goes...
You can store a value in a hidden/calculate prompt and make that value
change based on a previous answer.
calculate: if(selected(${gender}, 'male'), 'Dude', 'Not a dude')
Then you can use that calculate prompt in a label of another prompt to
show the value.
label: This person's dude status is ${dude_status}
> Thanks
Just be careful using calculations. They don't occur in sequential order
with the form. I'm sure there is a ruleset for when calculations happen,
but I don't know what it is and I haven't been able to figure it out. It
seems to be dependent on form size / number of other calculations, among
other things.
The bottom line is that the calculate could be run too early or too late to
capture the correct value. I had calculates doing a variety of things for
dynamic labels and had to take them out because they weren't reliable.
Sometimes they'd be fine, sometimes they wouldn't calculate before display
and they would leave a blank, or have an incorrect value. You can use an
if() with a default value to mitigate this to some extent, but it isn't
always sufficient.
Jason
On Sunday, November 17, 2013 11:01:12 PM UTC-5, Yaw Anokwa wrote:
> Damien,
> show the value.
> Yaw
> Need ODK services? http://nafundi.comprovides form design, server
> lookup..
> > Thanks
> Groups "ODK Community" group.
> an email to opendatakit...@googlegroups.com .
> > For more options, visit https://groups.google.com/groups/opt_out.
