We want to create a form with some field that they have to select an option from information before we added.
For example, countries and cities.
A have to (in the same form) create multiple countries and, in the next step i have a fieldgroup (city) with two fields: country and name. Country i must select from the before entries/data (select list) and name is a text field.
I understand the choice filter, but my problem is i haven't got any data to
pre-load.
For example make a form with two groups (both are repeat group to add
multiples):
1.- Mount
*mount_name
*mount_province
2.- Trees
*mount_name (options must be the possible mounts the user added in the
previously group) A select list (only can choose one)
*tree_name
Then i don't know the quantity of mounts and trees the user is going to add
in the form and i need, in the trees group the possibility to select the
mount user added before.
I hope i explain, now, better.
Br,
Jose
El domingo, 29 de noviembre de 2015, 2:39:07 (UTC+2), Yaw Anokwa escribió:
> Jose,
> Use a choice_filter. See
> https://groups.google.com/d/msg/opendatakit/LAp3vvsUtag/jvaQrih2CgAJ
> for an example.
> Yaw
> field.
> > Somebody knows how or if we can make it?
> > A lot of thanks.
> Groups "ODK Community" group.
> an email to opendatakit...@googlegroups.com .
pre-load.
multiples):
1.- Mount
*mount_name
*mount_province
2.- Trees
*tree_name
Br,
Jose
in-field training, and software development for ODK. Go to https://nafundi.com to get started.
field.
