Dynamic Texts in Hints
Hello,
I am working on a certain survey which needs some dynamic texts to appear
in the hints text. For example, Based on Q1 response, I would like to
output the value (of question 1) in my hint in the next question i.e. Q2 or
Qn. I need this the way you can do ${q1} in a label. When I do this in a
hint, it does not echo/output the value in Q1.
Thanks in advance.
Allan,
Works for me with the latest build. Attached is a sample form.
output.xml (998 Bytes)
output.xlsx (10 KB)
ยทยทยท -- Need ODK consultants? Nafundi provides form design, server setup, in-field training, and software development for ODK. Go to https://nafundi.com to get started.
On Wed, Jun 1, 2016 at 1:46 PM, Allan Nila Chongwe allanchongwe@gmail.com wrote:
Hello,
I am working on a certain survey which needs some dynamic texts to appear in
the hints text. For example, Based on Q1 response, I would like to output
the value (of question 1) in my hint in the next question i.e. Q2 or Qn. I
need this the way you can do ${q1} in a label. When I do this in a hint, it
Thanks in advance.
Yaw,
Thanks for the reply. I am using ODK Collect 1.4.10 (1061). Unfortunately
it is not working. Attached are my xml, XLSForm and screenshots.
Allan
test-dynamic-hint-and-default-values.xml (2.47 KB)
test-dynamic-hint-and-default-values.xlsx (12.3 KB)
ยทยทยท On Wednesday, June 1, 2016 at 3:11:44 PM UTC+2, Yaw Anokwa wrote: > > Allan, > > Works for me with the latest build. Attached is a sample form. > > Yaw > -- > Need ODK consultants? Nafundi provides form design, server setup, > in-field training, and software development for ODK. Go to > https://nafundi.com to get started. > > On Wed, Jun 1, 2016 at 1:46 PM, Allan Nila Chongwe <allanc...@gmail.com > wrote: > > Hello, > > > > I am working on a certain survey which needs some dynamic texts to > appear in > > the hints text. For example, Based on Q1 response, I would like to > output > > the value (of question 1) in my hint in the next question i.e. Q2 or Qn. > I > > need this the way you can do ${q1} in a label. When I do this in a hint, > it > > does not echo/output the value in Q1. > > > > Thanks in advance. > > > > -- > > -- > > Post: opend...@googlegroups.com > > Unsubscribe: opendatakit...@googlegroups.com > > Options: http://groups.google.com/group/opendatakit?hl=en > > > > --- > > You received this message because you are subscribed to the Google > Groups > > "ODK Community" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to opendatakit...@googlegroups.com . > > For more options, visit https://groups.google.com/d/optout. >
Yaw,
Sorry to bother you. It works. I omitted the "$" before {q1}. However, this
is not working with the default. How can I have a dynamic default value in
a textbox? Doing this outputs "${q1}".
Thanks in advance.
Allan
ยทยทยท On Thursday, June 2, 2016 at 12:27:33 PM UTC+2, Allan Nila Chongwe wrote: > > Yaw, > > Thanks for the reply. I am using ODK Collect 1.4.10 (1061). Unfortunately > it is not working. Attached are my xml, XLSForm and screenshots. > > Allan > > On Wednesday, June 1, 2016 at 3:11:44 PM UTC+2, Yaw Anokwa wrote: >> >> Allan, >> >> Works for me with the latest build. Attached is a sample form. >> >> Yaw >> -- >> Need ODK consultants? Nafundi provides form design, server setup, >> in-field training, and software development for ODK. Go to >> https://nafundi.com to get started. >> >> On Wed, Jun 1, 2016 at 1:46 PM, Allan Nila Chongwe wrote: >> > Hello, >> > >> > I am working on a certain survey which needs some dynamic texts to >> appear in >> > the hints text. For example, Based on Q1 response, I would like to >> output >> > the value (of question 1) in my hint in the next question i.e. Q2 or >> Qn. I >> > need this the way you can do ${q1} in a label. When I do this in a >> hint, it >> > does not echo/output the value in Q1. >> > >> > Thanks in advance. >> > >> > -- >> > -- >> > Post: opend...@googlegroups.com >> > Unsubscribe: opendatakit...@googlegroups.com >> > Options: http://groups.google.com/group/opendatakit?hl=en >> > >> > --- >> > You received this message because you are subscribed to the Google >> Groups >> > "ODK Community" group. >> > To unsubscribe from this group and stop receiving emails from it, send >> an >> > email to opendatakit...@googlegroups.com. >> > For more options, visit https://groups.google.com/d/optout. >> >
Allan,
I'm pretty sure defaults don't support ${} because defaults are loaded
into the model when the form loads and not as you iterate through it.
On Thu, Jun 2, 2016 at 1:35 PM, Allan Nila Chongwe allanchongwe@gmail.com wrote:
Yaw,
is not working with the default. How can I have a dynamic default value in a
Thanks in advance.
Allan
Yaw,
Allan
Allan,
On Wed, Jun 1, 2016 at 1:46 PM, Allan Nila Chongwe allanc...@gmail.com wrote:
Hello,
appear in
output
Qn. I
hint, it
Thanks in advance.
Groups
an
Yaw,
Thanks. I have just used a hint to inform the user to input the data as
expected. I.e. "You MUST enter 123 below unless otherwise". This might not
be the optimal solution but for now I think it's doing what needs to be
done.
Allan
ยทยทยท On 2 Jun 2016 13:59, "Yaw Anokwa" wrote:
Allan,
Yaw,
this
in a
Thanks in advance.
Allan
Yaw,
Unfortunately
Allan
Allan,
Hello,
appear in
output
Qn. I
hint, it
Thanks in advance.
Groups
send
an
https://groups.google.com/d/topic/opendatakit/PacR7prT_2g/unsubscribe.
