Is it possible to edit data after sending it to aggregate using ODK
collect? At least as supervisor or administrator? I'm asking this because
sometimes the clerks might make mistakes and we need to correct them in the
field.
Hi Roque,
The short answer is no. Aggregate wasn't designed to allow edits. Your
best bet is to stream the data to Fusion Tables or Spreadsheets and do
your edits there. The long answer is you can try ODK 2.0 (alpha and
not ready for production) or try some of the other ODK-compliant
servers (e.g., Ona, Kobo).
On Tue, May 2, 2017 at 5:20 AM, Roque Covane wrote: > Is it possible to edit data after sending it to aggregate using ODK collect? > At least as supervisor or administrator? I'm asking this because sometimes > the clerks might make mistakes and we need to correct them in the field. > > -- > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en > > --- > You received this message because you are subscribed to the Google Groups > "ODK Community" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to opendatakit+unsubscribe@googlegroups.com. > For more options, visit https://groups.google.com/d/optout.Thanks Yaw, I found a way around.
