Does ODK aggregate work with 64-bit PostgreSQL?
We want to separate our ODK app server (Linux) from its PostgreSQL database
server (Windows 2008) for security policy compliance reasons (No DBs in the
DMZ). Should we use 32-bit or 64-bit PostgreSQL on the Windows server? Does
it matter which? Does ODK support both versions because it is using the
JDBC Spring connector?
I've had a search around but no-one seems to specify whether 32-bit or
64-bit is the way to go.
Evan
It should work with both (the JDBC driver should hide this).
I am using the 64-bit PostgreSQL 9.1 server for testing.
Whether to use 32-bit or 64-bit depends upon your operating system. If the
OS is a 64-bit OS, then use the 64-bit server.
database server (Windows 2008) for security policy compliance reasons (No
DBs in the DMZ). Should we use 32-bit or 64-bit PostgreSQL on the Windows
server? Does it matter which? Does ODK support both versions because it is
using the JDBC Spring connector?
Evan
