Reference is made to an earlier request for support:
http://groups.google.com/group/opendatakit/browse_thread/thread/9cdb9c14555e169c?pli=1
I have gone through the procedure that Yaw presented but, I had a
hiccup during saving the form: the bind type is reset back to
"xsd:string"
Question:
How do I use PurcForms to add a barcode field to a form?
i've filed a bug at
http://code.google.com/p/purcforms/issues/detail?id=2 for daniel. can
you paste the xml source of your form at http://dpaste.com?
> "xsd:string"
> Question:
