I am trying to fetch data from entity dataset. It is working in Enketo but not in ODK collect. Collect shoring error "Could not import data from dss_data.csv. Reason: Columns[name,Name] match!"
I am sharing ODK xls and screen shots.
Have you perhaps defined an entity property with name Name? All entities get a lowercase name property defined. It looks like Collect is trying to treat columns case-insensitively but finding a match between columns called name and Name.
The error message is not helpful, we will look into how either the restriction can be lifted or the message can be improved.
I think for now you will need to create a new dataset with a new name to be able to move forward with Collect.
