I cannot convert the excel to xls form and it gives me the error: Error: dictionary update sequence element #0 has length 1; 2 is required
2. What app or server are you using and on what device and operating system? Include version numbers. ODK Collect, http://opendatakit.org/xlsform/
3. What you have you tried to fix the problem? yes google it, looked through the overstackflow, looked into the questionnaire....
It's unfortunately going to be really hard to pinpoint without a form. Perhaps you can do something like remove half the form, try to convert it, see if it works and then keep removing parts to try to hone in on where the problem is?
Another idea is that you could run pyxform from the command line and share the full error message. What you've shared is just a summary.
