Hi there
When i try and upload ODK Aggregate to Google AppEngine i get this error message:
"Error occurred during initialization of VM
Could not reserve enough space for 1126400KB object heap"
Please help!?!
Hi there
Please help!?!
I assume this is using the ODK Aggregate installer and the error is
occuring during the running of the upload script (after the final installer
screen, when a separate script (the upload script) runs and you have
entered your e-mail account and password).
Are you running the ODK Aggregate 1.4.7 installer?
It sounds like you have a non-standard Java installation that has specified
some very-wrong start-up configuration parameters.
Are you using Java 7? We have not tested with Java 8.
Do you have a _JAVA_OPTIONS environment variable defined?
Hi there
message:"Error occurred during initialization of VM
Could not reserve enough space for 1126400KB object heap"Please help!?!
Hello,
I am having the same error. Where you able to find a solution?
Thank you
(the original user never replied)
Same questions for you:
What OS are you running (MacOSX, Windows 10, etc.)
What version of ODK Aggregate are you trying to install.
What version of Java do you have? To see this, open a CMD (Windows) or
Terminal (Mac) window and type:
java -version
This should report something like:
C:\Users\Admin>java -version
java version "1.7.0_80"
Java(TM) SE Runtime Environment (build 1.7.0_80-b15)
Java HotSpot(TM) 64-Bit Server VM (build 24.80-b11, mixed mode)
The java version should be something like "1.7.xxxxx"
If it isn't see the instructions for installing Java.
https://opendatakit.org/use/aggregate/
Hello,
Thank you
El viernes, 15 de mayo de 2015, 10:23:43 (UTC-6), aida...@gmail.com escribió:
Hi there
