See attached form.
Error evaluating "/choice-name1/SEC1X/rSEC1X/cQHPARENA"
Fails in jr:choice-name(${QHPARENC},'${QHPARENC}')
This is used within a repeat group, and ${QHPARENC} is an element within that repeat group.
I've created an issue for this: https://code.google.com/p/opendatakit/issues/detail?id=885
choice-name1.xls (25 KB)
Ramon,
This form works in SurveyCTO's Collect, and it should have been fixed in
ODK Collect as per issue #854 (
https://code.google.com/p/opendatakit/issues/detail?id=854). Are you using
the latest version of Collect? You can find v1.4 rev. 1033 at
https://code.google.com/p/opendatakit/downloads/list.
Chris
On Wed, Aug 7, 2013 at 12:31 AM, Ramon de la Cruz Lazaro < rmdlazaro@gmail.com> wrote:
See attached form.
Yes I'm using the latest version ODK Collect v1.4 rev. 1033
2013/8/7 Christopher Robert
Ramon,
using the latest version of Collect? You can find v1.4 rev. 1033 at
Chris
See attached form.
https://groups.google.com/d/topic/opendatakit/nhrorn30A8U/unsubscribe.
Atte
Ramón De la Cruz L.
Hi Ramon,
I'm very sorry, but issue 854 wasn't listed as included in the latest ODK
Collect. I presume that it will be in the next release, but I'll let Mitch
or another core team member speak to that.
I must have created the confusion in my earlier reply to Maria, in which I
mentioned jr:choice-name() and linked to issue 854. I implied that it was
fixed in the latest ODK Collect, but it seems that I jumped the gun. Very
sorry for the confusion, but I do presume that jr:choice-name() will be
working soon!
Chris
On Wed, Aug 7, 2013 at 9:40 AM, Ramon de la Cruz Lazaro <rmdlazaro@gmail.com wrote:
2013/8/7 Christopher Robert crobert@surveycto.com
Ramon,
Chris
See attached form.
Atte
Ramón De la Cruz L.
OK. I have just updated the ODK Validate version used by XLSForm.
Everything should now work.
Also just uploaded the stand-alone ODK Validate 1.4 to the downloads page
(which includes this fix).
ODK Collect 1.4 has these changes, it was just that XLSForm did not use an
updated ODK Validate, and would not accept the form.
On Wed, Aug 7, 2013 at 7:24 AM, Christopher Robert wrote:
Hi Ramon,
working soon!
Chris
On Wed, Aug 7, 2013 at 9:40 AM, Ramon de la Cruz Lazaro < rmdlazaro@gmail.com> wrote:
Ramon,
Chris
See attached form.
Atte
Ramón De la Cruz L.
Thanks, Mitch! And sorry to have created confusion.
Ramon, I hope that it works for you now?
Chris
On Wed, Aug 7, 2013 at 7:24 AM, Christopher Robert <chrislrobert@gmail.com wrote:
Hi Ramon,
I mentioned jr:choice-name() and linked to issue 854. I implied that it was
working soon!
Chris
Ramon,
in ODK Collect as per issue #854 (
Chris
See attached form.
Atte
Ramón De la Cruz L.
Ok, I tested. The error continues both "ODK Collect 1034.apk rev 1.4" and
"1.4 for ODK ODK Collect Validate v1.4 thru v1.2.jar"
Attached my test examples
Ramon
choice-name1.xml (8.49 KB)
Chris
an updated ODK Validate, and would not accept the form.
On Wed, Aug 7, 2013 at 7:24 AM, Christopher Robert < chrislrobert@gmail.com> wrote:
Hi Ramon,
ODK Collect. I presume that it will be in the next release, but I'll let
Mitch or another core team member speak to that.
working soon!
Chris
Ramon,
Chris
See attached form.
send an email to opendatakit+unsubscribe@googlegroups.com.
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
OK. I've uploaded a new ODK Validate and ODK Collect (rev 1035). Try them.
There is a fix in the JR layer for this, just pushed.
The root cause was that your form placed all the selection choices into
external read-only instance blocks within the XML, rather than in-lining
the values. These external instances are called dynamic choice lists
because filters can be applied to them. The jr:choice-name() function
assumed the list of choices was always static, and never dynamic. The
change is to allow dynamic lists.
HOWEVER, this will ONLY work if there are no filters on the choice list
because the context in which to evaluate any filters is not available. If
filters are used, they cannot be filters that reference elements within
repeat groups. If they do, the results will either be incorrect or lead to
Forced Close events. I.e., if you are using jr:choice-name() to access the
name of a choice that is within a cascading select, it will not work.
On Wed, Aug 7, 2013 at 1:45 PM, Ramon de la Cruz Lazaro <rmdlazaro@gmail.com wrote:
Ramon
2013/8/7 Christopher Robert chrislrobert@gmail.com
Chris
page (which includes this fix).
Hi Ramon,
which I mentioned jr:choice-name() and linked to issue 854. I implied that
it was fixed in the latest ODK Collect, but it seems that I jumped the gun.
Very sorry for the confusion, but I do presume that jr:choice-name() will
be working soon!
Chris
Ramon,
Chris
See attached form.
the Google Groups "ODK Community" group.
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
It works. Thank you very much, Mitch.
Ramon
2013/8/8 Mitch Sundt
On Wed, Aug 7, 2013 at 1:45 PM, Ramon de la Cruz Lazaro < rmdlazaro@gmail.com> wrote:
Ramon
Chris
Hi Ramon,
be working soon!
Chris
Ramon,
fixed in ODK Collect as per issue #854 (
you using the latest version of Collect? You can find v1.4 rev. 1033 at
Chris
See attached form.
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
Atte
Ramón De la Cruz L.
