Hello All,
Please I need your help, I am trying to work on the ODK Connect source code and can't seem to get any step-by-step guide on the configiration on android studio. I open the project and keep getting this error:
"Error:Process 'command 'git'' finished with non-zero exit value 128"
I have tried all I can and still not making any headway on this. I am new to the use of android studio for development too.
Regards
First, follow the tutorials for Android Studio:
Once you have the general mechanics and the necessary libraries installed
on your computer, then progress to try to build the ODK Collect source code.
It sounds like there is something wrong with your Git installation. Or the
network delays are causing failures.
I use a separate Git tool ( i.e.,
https://www.atlassian.com/software/sourcetree/overview ) to pull all the
repositories to my local computer, then launch Android Studio and import
the build.gradle file.
You may want to do the same. It would help separate the Git tool issues
from any build issues.
On Mon, Nov 9, 2015 at 10:42 AM, kunleshipo wrote:
Hello All,
Regards
"ODK Developers" group.
Thanks Mitch, I will do that and get back.
http://developer.android.com/training/index.html
On Mon, Nov 9, 2015 at 10:42 AM, kunleshipo kunleshipo@gmail.com wrote:
Hello All,
Regards
https://groups.google.com/d/topic/opendatakit-developers/GE3Bh4oC2FU/unsubscribe
Hey Mitch, did you get a work around for this? I'm badly stuck too!
No. From the error, there appears to be something wrong with your
installation of Android Studio and/or git.
You might try uninstalling all of those and re-installing.
