Hello,
i imported ODK collect to Android studio, i get this error
Error:(13, 0) CreateProcess error=2, The system cannot find the file
specified
I have attached the error log file.
Kindy assist.
Newton Andebe.
idea.log (140 KB)
Hello,
specified
Kindy assist.
Newton Andebe.
idea.log (140 KB)
Look at the log and find an error that seems simple to fix. e.g.,
Caused by: net.rubygrapefruit.platform.NativeException: Could not start
'git'
For some reason, the gradlew.bat is not able to find an installation of git
on your system.
searching the web for "Could not start 'git'" gives:
git needs to be on your PATH.
Hello,
specifiedI have attached the error log file.
Kindy assist.Newton Andebe.
"ODK Developers" group.
Please be aware that we are still actively tweaking our build scripts and
AndroidStudio support is only on the 'development' branch. Things may or
may not work.
'git'For some reason, the gradlew.bat is not able to find an installation of
git on your system.searching the web for "Could not start 'git'" gives:
http://stackoverflow.com/questions/17007244/android-studio-cant-start-gitgit needs to be on your PATH.
On Tue, Sep 8, 2015 at 3:53 PM, newton juma newtonandebe@gmail.com wrote:
Hello,
Thanks Mitch.
Let me have a look at it.I will keep you posted on how it goes.
Kind Regards,
Newton.
Hello,
mitchellsundt@gmail.com--
https://groups.google.com/d/topic/opendatakit-developers/JA9v3TotnFg/unsubscribe
Thanks Mitch.
Let me have a look at it.I will keep you posted on how it goes.Kind Regards,
Newton.Look at the log and find an error that seems simple to fix. e.g.,
Caused by: net.rubygrapefruit.platform.NativeException: Could not start 'git'
For some reason, the gradlew.bat is not able to find an installation of git on your system.
Hello,
Error:(13, 0) CreateProcess error=2, The system cannot find the file specifiedI have attached the error log file.
You received this message because you are subscribed to the Google Groups "ODK Developers" group.
To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
mitche...@gmail.com--
You received this message because you are subscribed to a topic in the Google Groups "ODK Developers" group.
To unsubscribe from this topic, visit https://groups.google.com/d/topic/opendatakit-developers/JA9v3TotnFg/unsubscribe.
To unsubscribe from this group and all its topics, send an email to opendatakit-developers+unsubscribe@googlegroups.com.
Hi Newton,
I was wondering if you were able to fix this error using Mitch's advice? I cannot install Git onto my laptop right now so I cannot try the fix, that he posted, myself.
Kind regards,
Ryan
I have added a README.md to the collect project that describes how to set
up this project with AndroidStudio.
On Tuesday, September 8, 2015 at 10:08:47 PM UTC-7, newton juma wrote:
Thanks Mitch.
Newton.On Wed, Sep 9, 2015 at 2:04 AM, Mitch Sundt mitche...@gmail.com wrote:
On Tue, Sep 8, 2015 at 3:53 PM, newton juma newton...@gmail.com wrote:
Hello,
Groups "ODK Developers" group.To unsubscribe from this group and stop receiving emails from it, send
an email to opendatakit-developers+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
Google Groups "ODK Developers" group.To unsubscribe from this topic, visit
.To unsubscribe from this group and all its topics, send an email to
Hi Newton,
he posted, myself.Kind regards,
Ryan--
Thanks Sir for the heads up!
up this project with AndroidStudio.On Tue, Oct 13, 2015 at 10:14 AM, rbendo28@gmail.com wrote:
Thanks Mitch.
Hello,
Hi Newton,
Ryan--
Hi Mitch,
Thank you for adding the README on how to set up the project in Android Studio. It made it a little easier to understand. I've done everything you stated in the README, however, I still keep getting the same error as stated by Newton:
Gradle sync failed: CreateProcess error=2, The system cannot find the file specified
When I look in the error log, I see that git cannot start even though I have set the path to git to the directory of git.exe and it says it is working correctly. So I do not understand why my gradle is failing to sync.
Kind regards,
Ryan
What operating system are you working on? (Windows, Mac, Linux, Linux 64)?
Hi Mitch,
stated by Newton:Gradle sync failed: CreateProcess error=2, The system cannot find the file
specifiedWhen I look in the error log, I see that git cannot start even though I
working correctly. So I do not understand why my gradle is failing to sync.Kind regards,
set up this project with AndroidStudio.On Tue, Oct 13, 2015 at 10:14 AM, rben...@gmail.com wrote:
On Tuesday, September 8, 2015 at 10:08:47 PM UTC-7, newton juma wrote:Thanks Mitch.
Kind Regards,
Newton.
start 'git'For some reason, the gradlew.bat is not able to find an installation
of git on your system.searching the web for "Could not start 'git'" gives:
Hello,
Kindy assist.
Newton Andebe.
Hi Newton,
fix, that he posted, myself.Kind regards,
Ryan
I am using Windows 7
Drat! That's what I support It will be a considerable while before I
can look into this.
You should search the Intellij / Android Studio lists for similar errors /
issues.
I remember fighting with Intellij, Java, and git when I was setting up my
environment.
Don't remember the steps.
If you find a resolution, please let us know and I will update the README.md
64)?On Wed, Oct 14, 2015 at 10:12 AM, rben...@gmail.com wrote:
Hi Mitch,Thank you for adding the README on how to set up the project in Android
file specifiedWhen I look in the error log, I see that git cannot start even though I
Ryan
Thanks Mitch.
Kind Regards,
Newton.
Hello,
Kindy assist.
Newton Andebe.
send an email to opendatakit-developers+unsubscribe@googlegroups.com.For more options, visit https://groups.google.com/d/optout.
the Google Groups "ODK Developers" group.To unsubscribe from this topic, visit
Hi Newton,
Ryan
Ah alright, I see. Thank you for you quick response. You've been really helpful! I'll keep looking into it and if I find a solution, I'll let you know.
Thanks!
Ryan
Did anyone manage to get to the bottom of this issue? I have the same problem. Android Studio reports that Gradle project sync failed, with an error from collect\collect_app\build.gradle.
The Event Log reports the following:
15:32:02 Gradle sync started
15:32:12 Gradle sync failed: CreateProcess error=2, The system cannot find the file specified
Consult IDE log for more details (Help | Show Log)
This is a fragment of the idea.log file:
Caused by: org.gradle.process.internal.ExecException: A problem occurred starting process 'command 'git''
at org.gradle.process.internal.DefaultExecHandle.setEndStateInfo(DefaultExecHandle.java:196)
at org.gradle.process.internal.DefaultExecHandle.failed(DefaultExecHandle.java:325)
at org.gradle.process.internal.ExecHandleRunner.run(ExecHandleRunner.java:83)
... 2 more
at net.rubygrapefruit.platform.internal.DefaultProcessLauncher.start(DefaultProcessLauncher.java:27)
at net.rubygrapefruit.platform.internal.WindowsProcessLauncher.start(WindowsProcessLauncher.java:22)
at net.rubygrapefruit.platform.internal.WrapperProcessLauncher.start(WrapperProcessLauncher.java:36)
at org.gradle.process.internal.ExecHandleRunner.run(ExecHandleRunner.java:65)
... 2 more
Caused by: java.io.IOException: Cannot run program "git" (in directory "C:\Users\martin.ingham\FIND ODK\Android\odk\collect\collect_app"): CreateProcess error=2, The system cannot find the file specified
at net.rubygrapefruit.platform.internal.DefaultProcessLauncher.start(DefaultProcessLauncher.java:25)
... 5 more
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
... 6 more
I have set up the directory structure as per instructions in the Readme. The gradle-config project is checked out at tag 9.
I have Git installed, and have fixed the Path to Git executable in the default settings in Android Studio (to the exe in \cmd), and have added the path to the Path environment variable (both System and User just in case!).
Running out of ideas of things to look for now Any help would be appreciated!
Martin
I think you've done all the right things, but definitely sounds like a
path issue. Maybe try a reboot or re-install of git?
Consult IDE log for more details (Help | Show Log)This is a fragment of the idea.log file:
... 2 more
... 2 more
... 5 more
... 6 moreI have set up the directory structure as per instructions in the Readme. The gradle-config project is checked out at tag 9.
I have Git installed, and have fixed the Path to Git executable in the default settings in Android Studio (to the exe in \cmd), and have added the path to the Path environment variable (both System and User just in case!).Running out of ideas of things to look for now
Martin
My bad, I had included the git .exe in the Git directory in the Path variable! (facepalm)
