Hey,
I am trying to create my first ODK instance and am having trouble uploading
it and getting it running. I get the following error:
Error: Problem with JavaRosa Parsing Form:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData:
org.javarosa.xform.parse.XFormParseException: XML Syntax Error at Line: 11,
Column: 12!
I've gone through the form a couple time to look for mistakes, but can't
find any. I relatively new to this and was looking to do what I thought was
a pretty simple form, but for whatever reason, I can't get it to work. Any
help would be greatly appreciated. The XML file is attached.
Peter
PienkowData1.xml (2.53 KB)
Peter,
Try changing your prompts so the underlying data values do not start
with numbers. For example, 2013crop should be crop2013.
This is a bug and I just filed it at:
https://code.google.com/p/opendatakit/issues/detail?id=816
https://github.com/clint-tseng/odkbuild/issues/28
On Fri, Apr 26, 2013 at 4:38 AM, Peter Pienkowski peterpienkowski@gmail.com wrote:
Hey,
Column: 12!
Peter
Thanks, Yaw, that fixed it!
On Friday, April 26, 2013 4:01:09 PM UTC+2, Yaw Anokwa wrote:
> Peter,
> Yaw
> On Fri, Apr 26, 2013 at 4:38 AM, Peter Pienkowski <peterpi...@gmail.com > wrote:
> > Hey,
> uploading
> 11,
> > Column: 12!
> was
> Any
> > Thanks,
> > Peter
> Groups
> > "ODK Community" group.
> an
Peter,
Hey,
Column: 12!
Peter
Thanks Yaw, the solution suggested by you was useful to me as well
On Friday, April 26, 2013 at 7:31:09 PM UTC+5:30, Yaw Anokwa wrote:
> On Fri, Apr 26, 2013 at 4:38 AM, Peter Pienkowski wrote:
It is a spec requirement!
http://www.w3schools.com/xml/xml_elements.asp
Field names become XML elements and must follow these naming rules:
- Names can contain letters, numbers, and other characters
- Names cannot start with a number or punctuation character
- Names cannot start with the letters xml (or XML, or Xml, etc)
- Names cannot contain spaces
Any name can be used, no words are reserved.
Additionally, to keep everyone sane, do not use colons in names, and
punctuation is generally to be avoided (I recommend using only _ or - in
names).
On Fri, Apr 26, 2013 at 7:28 AM, Peter Pienkowski <peterpienkowski@gmail.com wrote:
Peter,
https://code.google.com/p/**opendatakit/issues/detail?id=**816https://code.google.com/p/opendatakit/issues/detail?id=816
https://github.com/clint-**tseng/odkbuild/issues/28https://github.com/clint-tseng/odkbuild/issues/28
On Fri, Apr 26, 2013 at 4:38 AM, Peter Pienkowski peterpi...@gmail.com wrote:
Hey,
uploading
org.opendatakit.aggregate.**exception.**ODKIncompleteSubmissionData:
org.javarosa.xform.parse.**XFormParseException: XML Syntax Error at
Line: 11,
Column: 12!
can't
was
Any
Peter
Unsubscribe: opendatakit...@**googlegroups.com
Groups
an
email to opendatakit...@**googlegroups.com.
For more options, visit https://groups.google.com/**groups/opt_outhttps://groups.google.com/groups/opt_out.
Hi all,
I am also having the same problem,
please have a look at my XML file
ThanksHFA11.xml (139.3 KB)
Liwindi
Hi @joshua_liwindi
what aggregate version do you use? I was able to upload your form.
Dear @Grzegorz,
Thanks for the feedback, I want to tell you that my form uploaded after a couple of tries, I wonder what the problem is,
I am running Aggregate v1.4.14
Liwindi
That's weird, I don't know what was wrong but that's great you have finally managed to upload your form.
Dear @Grzesiek2010,
I found such error in my form.
ODK Validate Errors:
XForm is invalid. See above for the errors.
org.javarosa.xform.parse.XFormParseException: Encountered a problem with display condition for node [${Fodder}] at line: (), Bad node: org.javarosa.xpath.parser.ast.ASTNodeAbstractExpr@1cd475
org.javarosa.xform.parse.XFormParseException: Encountered a problem with display condition for node [${Village}] at line: (), Bad node: org.javarosa.xpath.parser.ast.ASTNodeAbstractExpr@1cd475
Please help.Fodder-acreage-Estimation-Revised.xlsx (48.1 KB)
Fodder-acreage-Estimation-Revised.xml (61.2 KB)
Hi @Nikunj_Sakhiya
sorry for the late reply but I was on leave and I've just got back.
I investigated your form and noticed two problems:
- Column
relevant
where you use ()
- you should use yes/no like you do in required
column.
- In the
settings
sheet in column instance_name
you can't use spaces, so it can't be Dr.Nikunj Sakhiya
but it could be Dr.NikunjSakhiya
for example.
Let me know in case of any problems.
