Hi, I am having a problem with image sizes and the size of the blobs in the
Aggregate mySQL database.
The images are being split into multiple blob parts which is OK for
Aggregate but a problem with extracting data via a reporting tool.
I am happy to restrict the size of the image file to keep images within a
single blob part.
According to ODK - the image will only be split if the image is larger than
1 MB.
"The database tables are structured so that unbounded-size images can be
stored in the database. If your image size is under 1 MB, it is stored in
one data record, but if you have larger image files (or longer streaming
videos), they are split across multiple blob records, and writing the logic
to reconstruct them will be error-prone."
However, when I submit forms with images that are even 80 KB or less they
are split into 2 blob entries.
Do you have any idea why this might be - is there a setting in a property
file or code within Aggregate that determines these blob file sizes?
> single blob part.
> 1 MB.
> Cheers,
> Paul.
