Another question for you guys; on the wiki they have a link for some
examples of forms. There seems to be no examples there (at this link
http://code.google.com/p/opendatakit/source/browse/#svn/resources/forms
). Are there any examples of codes that you would not mind sharing?
Chloe
Hi Chloe:
The link is outdated; you should be able to find the samples here instead now:
http://code.google.com/p/opendatakit/source/browse?repo=forms
I'll go update the existing link.
—Clint
On Oct 15, 2010, at 1:16 PM, Chloe wrote:Hi,
Chloe--
The correct link is
http://code.google.com/p/opendatakit/source/browse?repo=forms.
Just so we can update the link where did you get that link from?
Cheers,
Waylon
On Fri, Oct 15, 2010 at 1:16 PM, Chloe wrote: > Hi, > Another question for you guys; on the wiki they have a link for some > examples of forms. There seems to be no examples there (at this link > http://code.google.com/p/opendatakit/source/browse/#svn/resources/forms > ). Are there any examples of codes that you would not mind sharing? > Thanks > Chloe > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en >Already replied, and found and updated the link. =)
—Clint
On Oct 15, 2010, at 1:34 PM, W. Brunette wrote:The correct link is
Cheers,
WaylonOn Fri, Oct 15, 2010 at 1:16 PM, Chloe chloelemarchand@gmail.com wrote:
Chloe--
