It’s great to hear that there is python package for odk form. If there’s more link for learning and practicing, pleas attache them here.
This is the tool that works behind the scenes to convert your Excel spreadsheets to valid forms. Most users won't need to interact directly with it and will instead use it through other form conversion tools.
If you're interested in seeing how it works, the source code is at https://github.com/XLSForm/pyxform. There isn't much documentation but the code is clean. When I started looking at it I started with the xls2xform command-line interface and followed the code from there. If you have any questions about it, I've split your initial comment out into a separate topic and you can ask here!
Ok, thank you very much. I’ll look it little by little.
