Export Issues
Hello,
My name is Seth and I work with CORE at NPS. I had a question about exporting data.
When utilizing the repeat option in the xls form builder and when multiple values are added to a cell via repeat option, the exported data results are in the form of a URL and not the actual recorded values. Is there a way around this?
Seth
Assuming you are using Aggregate. Use ODK Briefcase to download the
data from ODK Aggregate and generate a
csv file for the top-level group and separate csv files for each
repeat group underneath.
Here is a email chain that explains some of the reasons why the
feature is currently a lower priority for Aggregate:
http://groups.google.com/group/opendatakit-developers/browse_thread/thread/eef19a8d52b1a0bd
We do accept code patches so anyone can contribute.
Waylon
··· On Sat, Apr 28, 2012 at 11:13 PM, Gray, Seth (CIV) wrote: > Hello, > > > My name is Seth and I work with CORE at NPS. I had a question about > exporting data. > > > When utilizing the repeat option in the xls form builder and when multiple > values are added to a cell via repeat option, the exported data results are > in the form of a URL and not the actual recorded values. Is there a way > around this? > > > Seth > > -- > Post: opendatakit@googlegroups.com > Unsubscribe: opendatakit+unsubscribe@googlegroups.com > Options: http://groups.google.com/group/opendatakit?hl=en
