I have been trying to export my encrypted test data using ODK Briefcase and my public-private key pair, but every time I export it, the csv file is blank except for the variable names in the header. Has anyone run into this problem before or does anyone know if I am doing anything wrong.
Thank you,
Ryan
Did you get the success message when the export was completed?
On Wednesday, March 1, 2017 at 12:03:19 AM UTC+2, rben...@gmail.com wrote:
> Hi,
> Thank you,
> Ryan
After downloading the previous version, ODK Briefcase v1.4.9, I was finally able to decrypt my forms with my private key. I was originally using v1.4.10, which is still a fairly new version, to decrypt my forms but never had any luck. I'm not too sure, but there might be a bug in v1.4.10 since I was able to decrypt in v1.4.9. If I'm wrong about v1.4.10, please let me know.
Ryan
On Tuesday, February 28, 2017 at 2:03:19 PM UTC-8, Ryan Bendo wrote:
> Hi,
> Thank you,
> Ryan
I never noticed the message in the corner but no it did not complete. I
forgot to download the JCE but after I did so, it still failed. Here is my
error:
Error decrypting submission uuid8d2c8480-d625-4058-86e2-57aab74f124a Cause:
org.opendatakit.briefcase.model.CryptoException: Error decrypting
base64EncryptedKey Cause: java.security.NoSuchAlgorithmException: Cannot
find any provider supporting RSA/NONE/OAEPWithSHA256AndMGF1Padding
FAILED!
I am using java 8 on my computer but downloaded JCE for the Java 7 version
since it said so in the manual. Should I downgrade my java to java 7?
Thank you,
Ryan
Thank you,
Ryan
Hi Ryan,
Could you please comment on the issue at
https://github.com/opendatakit/briefcase/issues/65 and provide more
detail so we can try to reproduce?
We need to know your software/operating system, what steps you took,
and if you can, include the form and the keys. Note that the issue
tracker is public, so don't reuse the key.
>> Hi,
>> Thank you,
>> Ryan
> Ryan
> To unsubscribe from this group and stop receiving emails from it, send an email to opendatakit+unsubscribe@googlegroups.com.
