I was wondering after you uploaded data to your server if you could export
jpegs of sketches and photos taken to your pc? I have worked with a similar
program which has not allowed you to do that. Thanks
Matt
Matthew St. Pierre
Director of Field Operations
SDE, Inc.
p| 978.975.0500
c | 978.793.2631
f | 978.975.0550
354 Merrimack Street, Suite 200
Lawrence MA 01843-1755
mailto:mstpierre@sde-inc.com mstpierre@sde-inc.com
http://www.sde-inc.com/ www.sde-inc.com
http://twitter.com/sde_inc http://twitter.com/sde_inc
Yes, the ODK Briefcase tool can pull entire datasets off the ODK Aggregate
server down to your local machine, including all multimedia files.
If you then use ODK Briefcase to Export this local data to CSV format, the
relevant media files are copied into a media directory in the same
directory as the .csv file.
Alternatively, if you know the link to the image file (e.g., such as those
contained in the .csv generated when you Export CSV from within ODK
Aggregate), you can open that link in a browser, right-click, and save-as.
Or use your own scripts to traverse the .csv file and pull the images down
to your local machine.
On Thu, Jun 7, 2012 at 8:45 AM, Matthew St. Pierre wrote:
Hi,****
similar program which has not allowed you to do that. Thanks****
Matt****
Matthew St. Pierre****
Director of Field Operations****
SDE, Inc.****
p| 978.975.0500****
c | 978.793.2631****
f | 978.975.0550****
354 Merrimack Street, Suite 200****
Lawrence MA 01843-1755****
mstpierre@sde-inc.com****
www.sde-inc.com**
http://twitter.com/sde_inc****
