I'm trying to extract sub-string (e.g, first 4 digits) from a text entry
(Institution_name) to a field such as "Institution_code" using
calculate="substr('/data/Institution_name',0,4)", but this only results
---- /dat , where I expect the first 4 digits of the inserted Institution
name like "LEFT" function of excel.
The single-quotes around the path '/data/institution_name' mean that this
is a literal string value. To access the contents of that field, you
should write:
calculate="substr(/data/institution_name,0,4)"
i.e., no quotes around the path
On Mon, Nov 11, 2013 at 11:34 PM, Maeshal wrote:
Hello !!!
I tried this way (without quotes around the path i.e.
calculate="substr(/data/Institution_name,0,4)" ) too but it doesn't work.
ODK validator 1.3 says: "java.lang.StringIndexOutOfBoundsException: String
index out of range: 4"
"ODK collect v1.3 rev 1029" is unable to parse the form.
Any thing else that I should try? Please, suggest !
Thank you,
M
> should write:
> On Mon, Nov 11, 2013 at 11:34 PM, Maeshal <tito.f...@gmail.com wrote:
>> Hello !!!
>> Please help .... !
>> Thanks,
>> M
>> "ODK Community" group.
>> For more options, visit https://groups.google.com/groups/opt_out.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitche...@gmail.com
On Tue, Nov 12, 2013 at 9:16 PM, Maeshal wrote:
Thank you Mitch,
String index out of range: 4"
Thank you,
M
should write:
Groups "ODK Community" group.
