Facing ODK server problem even after END SCRIPT SUCCESS
after getting end script success, whenever am trying to put http://.appspot.com . its showing "404 thats an error, requested URL was not found on this server" pls help me out.
The url for your server would be something like:
https://YOURAPPNAME.appspot.com
With the badly formed URL you specified, 404 is the expected result.
404 is actually kind of an interesting result, since it implies that some server actually replied with it. I'd have expected a bad-URL or a DNS/TCP timeout.
@issa
Thank you so much for replying ..
However i managed to complete the process and now its showing “HELLO WORLD” only instead of opening the server whenever i request for the URL ".appspot.com"
can you please help me out ..?
@Mitch_S
Thank you so much for replying.
Yes, I typed "http://.appspot.com" and was getting this ERROR.
however I managed to complete some steps and now its showing HELLO WORLD only whenever I request for the URL "http://.appspot.com"
can u pls help me out ..
If you are seeing hello world, then you didn't install the server. Have you followed the instructions at https://opendatakit.org/use/aggregate? What version of the server are you using?
Thank you so much for replying..
Yes I followed the the instructions as described in https://opendatakit.org/use/aggregate/
version am using is v1.4.5
and Yes exactly its showing HELLO WORLD whenever am typing the URL myID.appspot.com
can you please help me out ?
If you are really using Aggregate 1.4.5, then that's the problem. It's very old and it's likely why you are having problems. You should use the latest version from https://opendatakit.org/downloads/download-category/aggregate/ (1.4.15).
Hello
I am using ODK aggregate 1.4.4 so after putting email address and password and then hit upload
So that I can get the URL. Then showing this error
404 URL requested Waz not found on this server please please help
What can I do now? To fix this error
