I am failing to pull data with Briefcase, any help on this please:
Error:
Fetching form definition resolving against briefcase form definitions Error parsing form definition: org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData: Javarosa failed to construct a FormDef. Is this an XForm definition?
error one
error two
preparing to retrieve instance data
aborting fetching submission chunks...
error three
Aborted. Skipping fetch of form and submissions...
Not all submissions retrieved: Error fetching list of submissions: Transfer of submission download chunk aborted.
Failed.
Welcome to the ODK forum, @Rutayuga! We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
We need more information to help you:
- Could you tell which Briefcase version, operating system, and java version you're using?
- Could you attach the form you're trying to pull?
Hello @ggalmazor
Thank you for the reply.
I will be glad for your support.
Briefcase version: ODK Briefcase-v1.11.0-beta.1
A1.xlsx (68.3 KB)
What was the solution to this?? I have the same errors.
