I have been trying to get odk-aggregate up and running in eclipse so that I
can make some additions but I have run into problems getting it to run.
Does anyone know what the source of the following error might be? I have
tried to pinpoint the possible problem and have run out of ideas.
objc[11954]: Class JavaLaunchHelper is implemented in both
/Library/Java/JavaVirtualMachines/jdk1.8.0.jdk/Contents/Home/bin/java and
/Library/Java/JavaVirtualMachines/jdk1.8.0.jdk/Contents/Home/jre/lib/libinstrument.dylib.
One of the two will be used. Which one is undefined.
Exception in thread "main" java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:491)
at
sun.instrument.InstrumentationImpl.loadClassAndStartAgent(InstrumentationImpl.java:382)
at
sun.instrument.InstrumentationImpl.loadClassAndCallPremain(InstrumentationImpl.java:397)
Caused by: java.lang.NoSuchMethodError:
sun.reflect.Reflection.getCallerClass(I)Ljava/lang/Class;
at
com.google.apphosting.utils.clearcast.ClearCast$1.run(ClearCast.java:293)
at
com.google.apphosting.utils.clearcast.ClearCast$1.run(ClearCast.java:291)
at java.security.AccessController.doPrivileged(Native Method)
at
com.google.apphosting.utils.clearcast.ClearCast.maybeSetClassLoader(ClearCast.java:291)
at
com.google.apphosting.utils.clearcast.ClearCast.staticCast(ClearCast.java:263)
at
com.google.appengine.tools.development.agent.AppEngineDevAgent.premain(AppEngineDevAgent.java:61)
... 6 more
FATAL ERROR in native method: processing of -javaagent failed
Dan
