Hello, the problem i am dealing with is putting some kind of "if yes" in a
field-list.
For example;
beginning a group with 1 question and a "score" section. In compliance with
the first question, i would like to see a 2nd question. If the answer is
yes, i want to see that question in the group. But if the answer is no, i
don't want to see it.
I did try to do that like we do if it's not a group question by using
${funds}='yes' on "relevant" but it's not working in a group. That question
also visible when i do that.
This is the normal and intended behavior. If you have questions that
should appear or not based upon answers to earlier questions, they
cannot appear on the same screen ("field-list" group), they must
appear on a subsequent screen.
field-list.
For example;
