Hello everybody:
I have xlsform which contains choice_filter for select_one and select_multiple:
when I view data or export them on ONA server with " Labels only" and "use choices lables" all answers appear in Labels except those who had the choice filter.
what is the problem then?
Hello Moteb_Marei,
I have been able to replicate the issue you are encountering. Our technical team is looking into the issue. I will update you once the fix has been deployed to Ona. Apologies for any inconvenience this has cause you.
Regards,
Megan
Has a solution for this been found? I am using some filters in a survey we are conducting and labels are disappearing in places I have used Filters
Hi @dmwanga
if it's a problem with ONA it might be better to ask there https://groups.google.com/forum/#!forum/ona-community
