I have finalised forms which ich sent. Some of them did get uploaded while others did not. They are still on the device but do not show up on the exported data. I checked and I do not have instance folders for these forms either.
I used ODK Collect v1.22.0 on a Samsung S3. I uploaded my data to the aggregate server.
I had the problem every day of the field work but usually the missing data showed up the following day. This was not the case in these circumstances.
Any help would be greatly appreciated.
Thank you
Esther
Hi @EstherS! Can you first check on your server to make sure you don't have any incomplete submissions? https://docs.opendatakit.org/aggregate-forms/#managing-submissions-manually.
If the submissions are on the device, you can try resending when you have a good connection. Go to Send Finalized Forms, then hit the ⋮ menu, then Change View, then Show Sent and Unsent Forms, then you can re-send. No need to worry about duplicates since Aggregate de-dupes forms with instanceIDs (the vast majority of forms have instanceIDs).
Hi @yanokwa,
thanks for your input. I reuploaded the finalized forms (thanks for that I did not know one could do this so easily) but this made me realize that the data also is not registered under finalized forms. So in the first round of sending they got lost. Is there anything I can do to recover this data?
The data is not in the app under finalized forms, there is not instance folder, and it is not on the server.
I have a hunch that the data is gone but maybe you guys know a way to recover it.
Thanks in advance
Esther
If the submission is not in the /odk/instances folder on the device, the data is indeed gone (likely deleted by the enumerator).
