Dear all
in a form I am designing, I have first a question "number active persons" (label: Active) then a second question "Total number of persons" (label: Total)
Active should be less or equal
Therefore I put for the "Total" question the following constraint .>= Active
But it is not working.
Any of you can tell me what I am doing wrong
Kind regards
Gertjan
The two questions cannot be on the same screen.
If you have a field that has a required, constraint or calculate formula,
the fields referenced within that expression cannot reside on the same
screen as the field that evaluates the expression.
On Tue, Aug 4, 2015 at 2:00 AM, wrote:
Dear all
Total)
Active
Kind regards
Gertjan
