Hello everyone !
I would like to load a form to use and the loading interface no longer appears.
I've got a bunch of questions for you!
- What version of ODK Aggregate are you using and on what platform (App Engine, Tomcat) are you using?
- How big is this form (and the attachments)?
- Have form uploads ever worked? What, if anything, has changed?
Hello !
I would like to thank you already for your reaction on my problem.
It should be said that I'm using ODK Aggregate v1.4.4 and tomcat. The
size of the attached files is between 16 kB and 311 KB.
Yes, the download of a form has already worked and it is after a
moment of use that this display appears
<< Nos pensées deviennent nos paroles, nos paroles deviennent nos actes,
nos actes deviennent nos coutumes, nos coutumes deviennent nos valeurs et
nos valeurs deviennent notre destinée >>
Guy Rolland KOUASSI* -
Administrateur Systèmes et Réseaux* -
Ingénieur Des Systèmes Numériques de Communication Téléphone : +(225)
44-744-156*
my odk aggregate version is v1.4.13 Production
44-744-156*
Very interesting! This might be a browser/cache issue, so first, I'd try a reboot, try another browser, or try another computer and see if that helps. Next, make sure you haven't enabled some ad-block or firewall that would prevent pages from loading. Finally, check your Tomcat logs to see if there are any hints as to what is going on.
Hi !
I really tried all the browsers (chrome, firefox and oepra) and I emptied
the cache
I even used a computer under ubuntu to access the ODK Aggregate server but
still the same thing. everything is OK
44-744-156*
Look at your Tomcat logs. Any hints as to what is going on? If you don't have access to the logs, talk to the person who installed the server.
Ok I will check and make you a return
thanks !
44-744-156*
