I'am facing this problem of failure of form submission from android
emulator to ODK Aggregate running on Tomcat apache as a localhost on
my laptop.I even tried giving ip address as 10.0.2.2 with the port
8080 (url: http://10.0.2.2:8080) and http://localhost:8080 but still
facing the same problem. I have tried everything that could be
possible but still can't figure out why my emulator is not able to
recognize the localhost ODK Aggregate Server. Please suggest
something.I would be really thankful.
regards,
Niti
Niti,
Try http://code.google.com/p/opendatakit/wiki/AggregateTroubleshooting
and let us know if that doesn't help.
On Sat, Mar 24, 2012 at 22:01, NITI SINGH wrote:
> Hi,
> regards,
> Niti
Yaw,
Thankyou for the link.I tried following:
- opening of port 8080 through netsh command
- changing the port
but still no progress. And on my pc i can access ODK Aggregate which
is running on tomcat on this url : http://127.0.0.1:8080 but through
my android emulator browser it is opening through http://10.0.2.2:8080..
but ODK Agregate is not getting open in the emulator but tomcat is
opening and also form are not getting submitted to
http://10.0.2.2:8080/ODKAggregate/Aggregate.html. it is showing
ERROR:not found (404) url http://10.0.2.2:8080/ODKAggregate/Aggregate.html/submission.
Thankyou for ur help
Niti
On Mar 26, 12:04 am, Yaw Anokwa wrote:
> Niti,
> Tryhttp://code.google.com/p/opendatakit/wiki/AggregateTroubleshooting
> Yaw
> > Hi,
> > 8080 (url:http://10.0.2.2:8080) andhttp://localhost:8080but still
> > regards,
> > Niti
Start here:
http://opendatakit.org/use/aggregate/tomcat-install/
Until you can open a browser from your phone to your PC, and see the Tomcat
Administration page or the Aggregate app running on it, it isn't going to
work.
If you just need to pull data off your phone onto your PC, you might want
to use ODK Briefcase. It can export CSVs, but not KML.
On Mon, Mar 26, 2012 at 12:29 AM, NITI SINGH wrote:
Yaw,
- changing the port
Niti
On Mar 26, 12:04 am, Yaw Anokwa yano...@gmail.com wrote:
Niti,
regards,
Niti
