If you are building a form in Excel, is it possible to format a result of a calculation to round it to a set number of decimal places, or to put a currency symbol in front? For example in the 'Tip' example, could you make the result show up as $5.25, rather than 5.24906 ?
Hi Natalie,
This is possible. You'll need to create a calculate type row that rounds
the value using a calculation column like this:
round(${number}, 2)
Then in the label just include an additional currency symbol like so:
$${tip}
Regards,
-Nathan
> currency symbol in front? For example in the ‘Tip’ example, could you make
> Thanks,
> *Natalie *
