I have data downloaded from ona server in a csv formate, is it possible to
push this data in an ODK Aggregate installed on my local machine.
I tried to pull the data using briefcase, but it didn't worked giving the
error: "Error parsing form definition:
org.opendatakit.aggregate.exception.ODKIncompleteSubmissionData:
org.javarosa.xform.parse.XFormParseException: XML Syntax Error at Line: 1,
Column: 5!"
ODK collect and enketo webforms are seamlessly sending data to the ona
server without any error and i can also export all the submissions in csv
from ONA. the same xform is uploaded on ODK Aggregate local server.
i am using ODK Aggregate 1.4.7 and ODK Briefcase 1.4.6
I don't know about uploading data into Aggregate. You should be able to
use briefcase to pull data from Ona or any ODK compliant server and
reupload it to aggregate.
Matt
Column: 5!"
i have tried Briefcase as the first option but didnt succeeded because of
error "Error parsing form definition:
Column: 5!"
Any help??
On Sunday, 29 November 2015 18:03:37 UTC+2, Matt Berg wrote:
> Hi Fawad,
> Matt
>> to push this data in an ODK Aggregate installed on my local machine.
>> Column: 5!"
>> Any ODK/ONA guru can help??
>> Fawad
>> "ODK Community" group.
It sounds like there is a problem with the form definition file (XML).
Download the form definition as XML, then run it through ODK Validate
This should produce a more verbose error message.
On Sun, Nov 29, 2015 at 8:17 AM, Fawad Raza wrote:
Thanks Matt,
Column: 5!"
Any help??
Hi Fawad,
the error: "Error parsing form definition:
Column: 5!"
Groups "ODK Community" group.
