We are running into a problem where if we send in a submission that
has several photos, the submission is getting broken up into several
entries in the form's _CORE table (_IS_COMPLETE = 0).
I do not understand why ODK does this. The issue is that when this
happens, there is no way to group together the _CORE rows to know
which data was submitted with the same form instance.
The best option we have come up with is to try and match the data
fields in the _CORE table, but this will not guarantee that we are
putting the correct pieces of data together - if one user submits
multiple form instances that contain identical data in the _CORE table
(and different data in the other tables), then how do we know where
the separation is?
My thought was to create a unique ID that would be a field in the
_CORE table and would be generated each time the user creates a new
instance of the form. The unique ID could be the username
+current_timestamp, or anything else that would be unique.
If the transmission to the server will be greater than 10MB, it is split
across multiple submissions. This is to bound the size of the Virtual
Machine running on the server.
With ODK Collect 1.1.7 and later, the bind for this element that replicates
the instanceID that would otherwise be generated by Aggregate would be:
You can construct your own instanceID expressions. However, you should
avoid symbols and punctuation other than colons and dashes since the
parsing logic within Aggregate is likely fragile if you go wild with
punctuation (and that is used later on when retrieving images, repeat
groups, etc.). If you do construct your own values, they must be less than
255 characters long and must be unique across all devices and submissions.
On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated <feltpadinc@gmail.com wrote:
the separation is?
Thank you for the tips about generating the Unique ID. Does this somehow
stop the data from appearing as multiple rows in the form's _CORE table? I
was expecting to have to join data based on the Unique ID, but none of my
entries have been broken into multiple rows since I implemented the Unique
ID - maybe just coincidence at this point, but I'm pretty sure my
submissions have exceeded the 10 MB limit.
Mitchell,
I guess I have a similar problem, but specifically with the repeating
groups (rosters): Is there a way that the looped data should be
joined to the parent data rather than having them coming as separate
with the generated parent keys? If this is not possible, then, how
well could I merge the two different data instances (parent and roster
tables); I am using stata 11.
Humphreys.
> To avoid this problem , specify an instanceID in the form, as defined here:https://bitbucket.org/javarosa/javarosa/wiki/OpenRosaMetaDataSchema For
> ODK Aggregate, you don't need to specify the namespace, just have a
> group in your form.
> calculate="concat('uuid:', uuid())"/>
> Mitch
> On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated > We are running into a problem where if we send in a submission that
> > the separation is?
> > Any ideas / comment would be greatly appreciated.
> Mitch Sundt
> Software Engineer
> University of Washington
> mitchellsu...@gmail.com
Yes, by specifying a unique ID in the form, you enable Aggregate to
identify and merge the values across the multiple transmissions, yielding
only one composite record of the results in Aggregate -- all the clerical
work is handled by the program, rather than by you.
Hi Mitch,
Just to clarify, this solution also works in preventing duplicate entries
when submittingf orms via ODK Collect/KoboCollect? So I just paste this the
following text in the beginning of any form and it will prevent duplicates
entries in Aggregate?
Will this field also be part of the csv output file? I'm keen on
implementing this solution for Phase 2 -- hoping that duplicates will be a
thing of the past. Thanks a million for the tip!
~DataMax
replicates the instanceID that would otherwise be generated by Aggregate
would be:
On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated <feltp...@gmail.com<javascript:> wrote:
the separation is?
If you have a form with a repeat group, you can use ODK Briefcase to
download the submissions to your local machine then use ODK Briefcase
(rather than ODK Aggregate) to Export to CSV that form data. This will
produce a CSV for the overall form, and a CSV for each repeat group in the
form definition. There are columns on the far right of the rows in these
files that enable you to pair up the data across these tables.
On Fri, Mar 30, 2012 at 3:53 AM, Humphreys Kabota < humphreys.kabota@investinknowledge.org> wrote:
Mitchell,
replicates
than
submissions.
On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated < feltpad...@gmail.com wrote:
the separation is?
On Thu, Aug 16, 2012 at 4:06 PM, DataMax wrote:
Hi Mitch,
~DataMax
would be:
On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated < feltp...@gmail.com> wrote:
the separation is?
Is there a way to link each form submitted with a personalized unique ID?
For example, we are surveying multiple households with multiple "repeat
groups." Each household is assigned a unique 7-digit ID at the outset of
the survey-- this is entered as an answer to a survey question. This ID is
the same for all members of the household. When we export mutiple completed
surveys to csv files using ODK Briefcase, the only way to tie each "row"
across multiple CSVs to a given household is to compare the KEY or
PARENT_KEY column in each CSV file.
Is there a way we could instead or in addition have the 7-digit unique ID
be the unique identifier that ties all rows or all individual answers of a
given survey together?
Sam
On Friday, March 30, 2012 5:54:16 PM UTC, Mitch wrote:
> That's a different issue.
> Mitch
> On Fri, Mar 30, 2012 at 3:53 AM, Humphreys Kabota < humphrey...@investinknowledge.org > wrote:
>> Mitchell,
>> Humphreys.
>> For
>> > group in your form.
>> replicates
>> than
>> submissions.
>> > Mitch
>> > > the separation is?
>> > > Post: opend...@googlegroups.com
>> > > Unsubscribe: opendatakit...@googlegroups.com
>> > Mitch Sundt
>> > Software Engineer
> Mitch Sundt
> Software Engineer
> mitche...@gmail.com
I had the same issue, and Yaw helped me out. You can insert the ID through
calculation, where the calculation = the name of the unique ID question. If
you're creating forms as xls and converting to xlm (the only way I know how
to do it) then you'd:
make sure you have a column called 'calculation'
after your begin repeat, enter a line with type: calculate
read_only: yes
calculation: ${name of ID variable}
Works like a charm.
-Victoria
On Monday, 28 January 2013 11:58:10 UTC, Sam wrote:
> Hi Mitch (or anyone else with an answer),
> Thanks,
> Sam
>> Mitch
>> On Fri, Mar 30, 2012 at 3:53 AM, Humphreys Kabota < humphrey...@investinknowledge.org> wrote:
>>> Mitchell,
>>> Humphreys.
>>> split
>>> For
>>> > group in your form.
>>> replicates
>>> than
>>> submissions.
>>> > Mitch
>>> table
>>> > > the separation is?
>>> > Mitch Sundt
>>> > Software Engineer
>> Mitch Sundt
>> Software Engineer
>> mitche...@gmail.com
On Jan 28, 2013 6:01 PM, "Victoria Trinies" wrote:
Hi Sam,
read_only: yes
Works like a charm.
-Victoria
Sam
On Fri, Mar 30, 2012 at 3:53 AM, Humphreys Kabota <humphrey...@** investinknowledge.org> wrote:
Mitchell,
split
replicates
be:
less than
submissions.
table
the separation is?
On Monday, January 28, 2013 12:31:54 PM UTC, Victoria Trinies wrote:
> Hi Sam,
> read_only: yes
> Works like a charm.
> -Victoria
>> Thanks,
>> Sam
>>> Mitch
>>>> Mitchell,
>>>> Humphreys.
>>>> split
>>>> here:
>>>> > group in your form.
>>>> replicates
>>>> be:
>>>> less than
>>>> submissions.
>>>> > Mitch
>>>> table
>>>> > > the separation is?
>>>> > Mitch Sundt
>>>> > Software Engineer
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
I am glad I came across this post. One quick question however, it there a
limit as to how many time one could have the calculate field carry forward
the ID as you illustrated, say if one has multiple separate repeat groups
within the same form?
Any help will be highly appreciated.
Thanks.
Ezra
On Monday, January 28, 2013 3:31:54 PM UTC+3, Victoria Trinies wrote:
> Hi Sam,
> read_only: yes
> Works like a charm.
> -Victoria
>> Thanks,
>> Sam
>>> Mitch
>>>> Mitchell,
>>>> Humphreys.
>>>> split
>>>> here:
>>>> > group in your form.
>>>> replicates
>>>> be:
>>>> less than
>>>> submissions.
>>>> > Mitch
>>>> table
>>>> > > the separation is?
>>>> > Mitch Sundt
>>>> > Software Engineer
>>> Mitch Sundt
>>> Software Engineer
>>> mitche...@gmail.com
You insert the id as often as you'd like. The only catch is that the
instance/data name has to be unique.
On Tue, May 14, 2013 at 6:29 AM, Rwakazooba Ezra Aliija rwakazooba@gmail.com wrote:
Hello Victoria, thanks for sharing this.
Thanks.
Ezra
Hi Sam,
read_only: yes
Works like a charm.
-Victoria
groups." Each household is assigned a unique 7-digit ID at the outset of the
survey-- this is entered as an answer to a survey question. This ID is the
Sam
Mitchell,
split
Virtual
replicates
be:
should
less than
submissions.
On Thu, Mar 29, 2012 at 10:33 AM, Feltpad Incorporated <feltpad...@gmail.com wrote:
several
table
the separation is?
Thanks Yaw, I going a head to try it out.
Will let you know how it goes.
Regards
Ezra
On Tue, May 14, 2013 at 4:30 PM, Yaw Anokwa wrote:
Ezra,
forward
Thanks.
Ezra
Hi Sam,
through
question. If
how
read_only: yes
Works like a charm.
-Victoria
ID?
of the
the
"row"
ID
of a
Sam
will
in the
these
Mitchell,
roster
split
Virtual
replicates
be:
should
the
with
repeat
less than
submissions.
that
several
this
are
table
where
the separation is?
new
a
forward
groups
Thanks.
Ezra
Hi Sam,
through
question. If
know how
read_only: yes
Works like a charm.
-Victoria
ID?
"repeat
of the
is the
completed
"row"
unique ID
of a
Sam
will
in the
these
Mitchell,
repeating
roster
split
Virtual
replicates
would
be:
should
the
with
repeat
less than
submissions.
that
several
this
know
data
are
submits
table
where
the separation is?
the
new
there a
forward
groups
Thanks.
Ezra
Hi Sam,
through
question. If
know how
read_only: yes
Works like a charm.
-Victoria
unique ID?
"repeat
outset of the
is the
completed
"row"
unique ID
answers of a
Sam
Briefcase
will
in the
these
Mitchell,
repeating
separate
roster
is
split
Virtual
replicates
would
be:
should
the
with
repeat
less than
submissions.
that
several
this
know
data
are
submits
_CORE
table
where
the separation is?
the
a new
