Dear Team,
i want to locate Geopoint Accuracy 10m
when i used accuracyThreshold 10 then Accuracy comes 18.01 m
Try and use below software in your phone.
I am sure that this will helpful for you.
@iamnarendrasingh
i am using it in a form and at end of form i have to collect GPS
There isn't enough information in your initial question.
What version of Collect are you using and on what device and operating system? Include version numbers. Also can you attach the XLSForm so we can be sure the form was designed correctly?
