ODK Collect reports an accuracy of coordinates that never gets better than 3.9 metres (obtained consistently) despite thresholds being set. From initial analysis, this seems about right. Using Doogee 68Pro rugged phones, which have internal GPS linked to GPS/GLONASS/BAIDOU/GALILEO systems; other GPS applications display sub 2-metre accuracy levels. When accuracy thresholds are set in the form, Collect keeps on looking until the user interacts to save, always producing a report of 3.9 metres. When there are no thresholds set, Collect immediately saves the coordinates at the point that the accuracy slips under 5, producing a range of readings between 4.7 to 4.9 metres. Not sure whether this a hardware or a software issue? If the former, has anyone used Doogee phones before? If the latter, is there something we can do in ODK to improve accuracy?
Hosted on Digital Ocean, managed through Aggregate & Postgres databases. Likely culprit is the Doogee 68Pro phones running Android
Changing thresholds in the forms
