GPS - segments in geotrace
Dear community,
Is there a way to draw several segments on a geotrace question?
We are using a loop at the moment but the problem is that is does not allow the enumerator to visualize all segments on a same background.
Thanks for you support and answers, as usual :slight_smile:
Emma
Hi @Emma_Joseph_Oudin This is not possible at the moment.
When you draw a new geographic object, it cannot be displayed in the context of those created before in the form, within the same "field session".
Such a feature was discussed in a "geo" related topic :
