the begin repeat has a trigger that refers to the date field when I delete the date the first group is cleaned but if I add a second this should also be deleted as I can control that?
Hi @user9192
We're glad you're here. When you get a chance, please introduce yourself on this forum thread. I'd also encourage you to add a real picture as your avatar because it helps build community!
could you attach your xls form so that we can better understand your case?
rentprogrammesupport.xlsx (14.6 KB)
thanks for the input and help
