How can we export data that is collected in group in a csv file? As it gives a link to the server to see the group data - but we cannot actually see the data in csv
Try using ODK Briefcase to download you data from Aggregate. Once the data
has been downloaded to a computer Briefcase should turn the repeat data
into separate CSV files.
Cheers,
Waylon
gives a link to the server to see the group data – but we cannot actually
see the data in csv****
Thanks****
Irum Jamshed | Manager - Data Management International Rescue Committee
Irum.Jamshed@pakistan.theirc.org | +92 91 5703310 (Ext-105) | rescue.org
From: opendatakit-developers@googlegroups.com [mailto:opendatakit-developers@googlegroups.com] On Behalf Of W. Brunette
Sent: Friday, May 10, 2013 12:54 PM
To: opendatakit-developers@googlegroups.com
Subject: Re: [ODK Developers] Group data - urgent help needed
Try using ODK Briefcase to download you data from Aggregate. Once the data has been downloaded to a computer Briefcase should turn the repeat data into separate CSV files.
Cheers,
Waylon
On Fri, May 10, 2013 at 12:48 AM, Irum Jamshed <Irum.Jamshed@rescue.orgmailto:Irum.Jamshed@rescue.org> wrote:
You can use ODK Briefcase to export such data. It will export separate .csv
files for the groups, linked to the primary .csv by unique ID's.
Chris
Thanks****
into separate CSV files.****
Thanks****
Thanks - just installed the briefcase and its working fine
Irum
Sent: Friday, May 10, 2013 1:02 PM
You could export your data to Google FusionTables or Google Spreadsheets and download the csv from those services. ODK Briefcase should be easier.
Cheers,
Waylon
Thanks****
I guess using ODK Briefcase would be much simpler.
[mailto:opendatakit-developers@googlegroups.com] On Behalf Of Irum Jamshed
Sent: 10 May 2013 13:29
Subject: RE: [ODK Developers] Group data - urgent help needed
separate CSV files.
data in csv
