I have successfully collected survey data using the ODK technology thanks
to information shared on the ODK website and the ODK Community.
However, I have started preparing my data set for analysis in Stata and
have detected that the csv data files from ODK Briefcase show variable
labels (string characters) in the data rather than numeric codes. For
example, on gender, “male” appears in the data instead of “1”, and “female”
rather than “2”. I just realized that the data appear this way because of
how I named question listings under the “choices” sheet in my ODK program
file. I thought numbers were not acceptable under the ‘name’ column on the
“choices” sheet but I have noticed that it is possible to use numbers and,
for some reason, I missed that part when I was designing my form.
Because I am now faced with raw data that is showing string entries instead
of numerical codes, I wanted to check with you all to see if someone knows
how to solve this issue in ODK (or other faster way to switch the data
entries from string to numeric codes). The obvious option to me now is
recoding the entries to numerical values either manually (which is a lot of
work prone to errors) or try to import into Stata and recode which is also
a cumbersome fix.
Please let me know if this issue could be resolved in a simpler way.
I'd write a Python script to process the CSV to do the find/replace.
I'm not a Stata expert, but there has to be away to do a find/replace
of values. https://github.com/matthew-white/odkmeta might be able to
help.
Need ODK consultants? http://nafundi.com provides form design, server
I have successfully collected survey data using the ODK technology thanks to
However, I have started preparing my data set for analysis in Stata and have
detected that the csv data files from ODK Briefcase show variable labels
(string characters) in the data rather than numeric codes. For example, on
gender, “male” appears in the data instead of “1”, and “female” rather than
“2”. I just realized that the data appear this way because of how I named
question listings under the “choices” sheet in my ODK program file. I
thought numbers were not acceptable under the ‘name’ column on the “choices”
sheet but I have noticed that it is possible to use numbers and, for some
work prone to errors) or try to import into Stata and recode which is also a
cumbersome fix.
Yaw,
Thanks for your suggestions.
I will check with the odkmeta group.
Regards,
Mike
On Thu, Oct 1, 2015 at 9:22 PM, Yaw Anokwa wrote:
Mike,
help.
thanks to
have
on
than
named
“choices”
instead
knows
of
also a
cumbersome fix.
The easiest option may be for you too look into the Stata 'encode' command.
~lb
On Friday, October 2, 2015 at 6:47:50 PM UTC+6, Mike Nyarko wrote:
> Yaw,
> Regards,
> Mike
> On Thu, Oct 1, 2015 at 9:22 PM, Yaw Anokwa <yan...@nafundi.com > wrote:
>> Mike,
>> help.
>> Yaw
>> On Fri, Oct 2, 2015 at 3:23 AM, Mike Nyarko <cashst...@gmail.com > wrote:
>> > Dear ODK Community,
>> thanks to
>> have
>> on
>> than
>> named
>> “choices”
>> some
>> instead
>> knows
>> lot of
>> also a
>> > cumbersome fix.
>> > Thanks,
>> > Mike
>> > Post: opend...@googlegroups.com
>> > Unsubscribe: opendatakit...@googlegroups.com
>> > Options: http://groups.google.com/group/opendatakit?hl=en
>> > You received this message because you are subscribed to the Google
>> Groups
>> > "ODK Community" group.
>> > To unsubscribe from this group and stop receiving emails from it, send
>> an
>> > email to opendatakit...@googlegroups.com .
>> > For more options, visit https://groups.google.com/d/optout.
>> You received this message because you are subscribed to a topic in the
>> Google Groups "ODK Community" group.
>> To unsubscribe from this topic, visit
>> https://groups.google.com/d/topic/opendatakit/eas2DPf2LxA/unsubscribe.
>> To unsubscribe from this group and all its topics, send an email to
help.
thanks to
and have
labels
example, on
than
named
“choices”
some
instead
knows
lot of
also a
cumbersome fix.
Groups
an
help.
thanks to
and have
labels
example, on
rather than
named
“choices”
some
instead
knows
lot of
also a
cumbersome fix.
Groups
send an
