I have built a form in odk build. it has follow up questions. when I export as xlsForms, the follow up questions do not turn up where they should. If I other wise try exporting into xml, it works. now, I want a background recording, this I see only in xlsforms. how do I do both the things, use follow-up questions as well as use background recording? if something to add in xml code, I can do if tought
odk collect 1.30.1; central 1.2.2; and build.getodk.org
add followup questions using odk build, export the form to xlsForms then upload on central, same symptoms reappear.
