I have a form which has a case of select one(yes or no), but I want to do if
the choice is yes and then you find possibility to repeat a group of
question and you can save new data on them for the same Id_survey, until
your choice is no.
Here the way I understand it, I think that it is like if you had a table
data in then you put a loop, "as long as the choice is true repeat the
table" and you will increment a counter table. It is what I think but I do
not know how to make it work in xlsform.
So, in the case of begin group, I do relevant= selected(${yes_no}, 'yes')
is not work.
Haven't thought hard about it, but that seems like it should work.
What if you put the relevance in a group outside the repeat instead of
in the repeat?
your choice is no.
is not work.
