buenos, dias alguien me puede ayudar con la columna calculation
Good moring someone can helpme with calculation column?
Elis
Elis
What specific problem are you having with the calculation column?
hello everyone, I had problem with the constraint and the calculate column, I want that the total of a serie, be validate with other value estableshid in other cell before Formulario_prueba.xlsx (27.9 KB)
I want validate the result of row 20 with the value of row 6
thanks
To confirm...
for area_parcelas you ask for a decimal value for the total area of all plots:
38. Cuál es la superficie total de todas las parcelas que tiene Ud.
later, you ask for the values for area for each type of plot:
1.Casa/bodegas/trojas/huerto
2.Cultivos anuales o temporales
3.Cultivos permanentes o semi-perenmes
4.En descanso o tacotales
5.natural
6.Pasto mejorado
7.Bosques
8.Otro
and you want to make sure that the value for area_parcelas matches the sum for the answers to the 8 plot types? and require that the two match before the user may continue with the survey?
good morning nice to met wiht you
I want that the value set in cell c6 will be same of the result of calculate in cell c20, if the result is diferent, show a messages for correct a value en the sum operation
Thank you
sorry for my bad english
elias
precisely that is I want to do
Something like this should do what you want?
| type | name | label | required | constraint | constraint_message | appearance |
| decimal | area_parcelas | 38. Cuál es la superficie total de todas las parcelas que tiene Ud. | ||||
| begin group | uso_suelofinca | 41. Sobre el uso del suelo en toda su finca: ¿Puede indicarnos qué cultivos ocupan su finca? Recuerde que el total del area que indico en la pregunta 38 fue de ${area_parcelas} manzanas | field-list | |||
| decimal | casa | 1.Casa/bodegas/trojas/huerto | yes | |||
| decimal | cultantemp | 2.Cultivos anuales o temporales | yes | |||
| decimal | culpersemiper | 3.Cultivos permanentes o semi-perenmes | yes | |||
| decimal | tacotal | 4.En descanso o tacotales | yes | |||
| decimal | natural | 5.natural | yes | |||
| decimal | pastmejo | 6.Pasto mejorado | yes | |||
| decimal | bosque | 7.Bosques | yes | |||
| decimal | otro_usosuelo | 8.Otro | yes | ${area_parcelas} = (${casa} + ${cultantemp} + ${culpersemiper} + ${tacotal} + ${natural} + ${pastmejo} + ${bosque} + ${otro_usosuelo}) | Please check that your answers add up to the amount indicated in question 38. All 8 questions must be answered, please answer 0 if 0. | |
| end group |
Thank you, very much, It was just what I needed
