Help with calculation error message --trying to use calculate function to create a score
getting the following error when converting xlsform to ODK Xform
Error: ODK Validate Errors:
Something broke the parser. See above for a hint.
Error evaluating field 'heart_rate_score' (${heart_rate_score}[1]): The problem was located in Calculate expression for ${heart_rate_score}
XPath evaluation: cannot handle function 'if' requires 3 arguments. Only 7 provided.
Caused by: org.javarosa.xpath.XPathUnhandledException: The problem was located in Calculate expression for ${heart_rate_score}
... 10 more
The following files failed validation:
${SATS} ODK XLSForm .xml
try to manually convert XLS form
carefully reviewed the formula
SATS ODK XLSForm .xlsx (22.3 KB)
Your parenthesis are not matched properly. With 3 if statements nested, it should look like this:
if(expression, then, if(expression, then, if(expression, then, else)))
Your relevant expressions for lines 40-43 are invalid. For example, if(${tews} >=7) is invalid. The format for an if statement is:
if(1, 2, 3)
where...
1 = statement to evaluate,
2 = value if statement is true, and
3 = value if statement is not true
So you would need to use something like:
if(${tews} >=7, true, false)
But that is redundant. You don't need to use an "if" statement, it just needs to evaluate to true or false so you can use only:
${tews} >=7
See the highlighted cells on this edited file:
SATS ODK XLSForm_edited.xlsx (22.4 KB)
It no longer reports an error when checked with https://getodk.org/xlsform/
More info in the docs:
Thanks so much! It worked
