Hello house, I am new to ODK. I designed a questionnaire using XLSform,and I got this error when I tried to convert to XML.
'Error: There has been a problem trying to replace ${product type} with the XPath to the survey element named 'product type'. There is no survey element with this name.'
Can someone kindly help out here.
Hi Yaw, thank you for your prompt response.
Unfortunately I am still experiencing the same error after I made the
correction and even deleted that particular product type question from the
questionnaire it still displays the same error message
Hi there,
In the name column, you probably have a prompt called "product_type".
You have tried to refer to it somewhere else in your form (maybe in
constraints or relevance) as "product type" (without the underscore).
Deleting the question won't help. Somewhere you are referencing that
question. Search for "${product type}" in your form and change things
there.
